MEFI 1 interface 10-pin cable
Try ODB they can point you to the web site that sells all the connectors.
Give them a call they are good guys to work with.
http://www.obd2allinone.com/sc/details.asp?item=mefi4b
Are you looking for the connector that plugs the EFI harness into the MEFI 1? I think it is a 32 pin, not a 10 pin connector.
Try this link to get the part numbers you need:
http://connectors2.delphi.com/dcsgdm...100Wheader.pdf
This is for a MEFI 3, but I think the MEFI 1 uses the same connector (a Delphi Micro-Pack 100). Once you find the part numbers, search for them on the Mouser.com site. They should have everything you will need, and they ship very quickly.
If you are looking for the connector that connects the EFI harness to the charging harness, I believe it is a Delphi Metri-Pack 150 connector. I can get you info on that as well if you need it.
