Tach problem....?
Hello everyone I'm new to the forum but have been glued to it since I've joined.
I have an issue with one of my tachs on my 02 Outlaw 29' that I just purchased last month. It has two 496's and as of last week one of my tachs is acting up.
When I was cruising around on the lake this last weekend the alarm went off and I looked at the gauges to see one of my tachs had stopped responding. I backed off the throttles only to have the tach start reading again.... I then leaned back into the throttles and it was responsive for a second then went inop again.
I pulled the gauge panel loose and checked the connections and they were all tight.
What else can I trouble shoot?
Also what motor oil and other fluids should I be running in this sucker being I'm still green.
Run Mercury 25W40 or if your a synthetic man 15W40...drives Merc HiPo drive lube
