alpha 1 counter rotate
I have been searching for the last month and a half for a counter rotating alpha 1 gen 1 right now I have 2 standard rotating drives. They sell those SE stuff but im a little scared of that stuff and new mercruiser stuff is pretty expensive does anyone know of a shop around st. louis that I may wanna try I tried every shop I know of around here any help would be great
I had a 87 Scarab that had Alpha drives on it and one was the CR drive. To answer your questions, The impellor is the standard one, it does not spin backwards. On the CR alpha, the only thing that spins reverse is the lower gears. It was told to me that the CR drive has a slightly beefed up reverse gear(which is actually the forward gear). It was always a pain and was the one which would blow up, but I did have 454s pushing them. Whenever I replaced one I got it from Jasper Engines as a factory rebuild.
