33 Outlaw swim platform removal >
Old 09-09-2010 | 12:22 PM
Default 33 Outlaw swim platform removal
Guys I'm getting ready to powdercoat my swim platform..So I need to remove it, and I am wondering what I am going to run into trying to get it off the transom...what can you suggest for me to bring as far as tools and things...? I am guessing/hoping the bolts are like laggs, and will just pull out using an air impact..will I have any surprises!
thank you!
Bajapred is offline
Old 09-09-2010 | 12:26 PM
I fairly shure the top bolts are thru bolted, but I know the
bottom one's are lagged.
JaayTeee is offline
Old 09-09-2010 | 03:24 PM
Custom Interiors & More
YEP!
Hey, a big tree (maybe) to wrap a tow strap around & to the platform, as your pull the boat with your pickup to break the seal.....
XT-Innovator is offline
Old 09-12-2010 | 09:45 PM
I took all of the bolts out except a couple of the top through bolts, which I loosened way up, then hooked an engine hoist to the back of the platform and put a bit of upward pressure on it, jumped up and down on the platform a couple of times, and it came loose pretty easily.
pwam1 is offline
Old 09-14-2010 | 05:00 AM
She came off like butta...have her powdered up and back on by this weekend! thanks guys
Bajapred is offline
Old 09-14-2010 | 06:40 AM
Has anyone tried to put a spray on coat like Linex or Rhino on the platform?
bmtbandit is offline
Old 09-14-2010 | 11:44 AM
jfm
Just make sure you don't use 5200 to put it back on.
jfm is offline
Old 09-15-2010 | 04:12 PM
I'm gonna just use some silicone sealant...
Bajapred is offline
Old 09-15-2010 | 05:18 PM
I was thinking on trying this on the old platform that I had. 3M even makes it in a spray can now....
Old 09-16-2010 | 06:31 AM
Just seems like a perfect fit to me. The stuff doesn't fade, is near bullet proof, and is textured on its own, so no need for the tape.
