winterize outdrive and motor >
Old 09-11-2010 | 12:38 PM
Default winterize outdrive and motor
first boat, just seeing what i should do to winterize beside change oil, and add anitfreeze....should i do anything to the outdrive? change the oil maybe? its a 454 Mag, with a bravo 1 outdrive
prostock3 is offline
Old 09-11-2010 | 03:10 PM
Make sure you get all the water out of drive and block
firehawkcat is offline
Old 09-12-2010 | 12:53 AM
If you don't know how to do it and don't have somebody to show you, then you should have it done by a professional. The risk of not winterizing correctly could be a $10,000 mistake.
Griff is offline
Old 09-12-2010 | 07:49 AM
Too Stroked's Avatar
X2 on this one. Every spring we get 3 or 4 sheepish looking folks that come in with a cracked block, manifolds, coolers, etc. and wonder how it happened. Every single time, they (eventually) say they tried to save some money by winterizing it themselves. Every single time, they end up spending 10x what they "saved" in replacing everything. Sad, but true. Don't join the club.
Too Stroked is offline
