Bulletproof TRS / Trans Package - Input Needed >
Old 09-13-2010 | 03:04 PM
fantastixvoyage's Avatar
Default Bulletproof TRS / Trans Package - Input Needed
Having only owned Bravo1 boats in the past I am starting from scratch when it comes to TRS applications. just picked up a 24 with a TRS and want to make it as bulletproof as possible.
What is the best trans to use? Is there any difference in them I need to be away of (tailstock configuration,mounting configuration,etc)? I have a Merc Trans now but heard there are better options.
Mods for the TRS? What is available/popular?
fantastixvoyage is offline
Old 09-13-2010 | 10:09 PM
Audiofn's Avatar
Charter Member #232
How much HP you running? Borge Warner Tranies are the stronger version but they do move the motor forward.
Put your best foot forward!
Audiofn is offline
Old 09-14-2010 | 07:04 AM
If you want a bulletproof tranny the only way to go is a crash box or shiftable crash box. http://www.offshoreonly.com/forums/g...crash-box.html The crash box is basically a gear set like a manual transmission in a car. Problem with a regular one is you can not shift them under load (ie engine running) so they were named "crash boxes" because people would crash into docks Lowers can be found for TRS drives to beef them up, many call this set up a Merc #2 drive.
4bus is offline
Old 09-14-2010 | 07:57 AM
cigrocket's Avatar
I have a 71C BW tranny, it is an upgarade from the merc trans II. And you do not need to move the motors foward. They can be beefed up to Huber 925 Specs. If you are interested, I will sell it on the cheap side, I no longer own that boat. It is in excellent exterior shape, it does need new clutch plates, it slips. But it would be the best option for you once it is rebuilt. I had my others done at Texoma Marine Gear and they did an awesome job and I never had any problems. I was running 675 HP N/A in the Cigarette Mistress that I used to own. That way you are starting with a quality piece.
Let me know
cigrocket is offline
Old 09-14-2010 | 12:29 PM
CIG3's Avatar
Call Marc at Bam 954 545 8681
CIG3 is offline
Old 09-14-2010 | 01:03 PM
Hey guys thanks for all the great input. As for power, lets just say it will run in class 6 and leave it at that
Old 09-14-2010 | 04:07 PM
cigrocket's Avatar
message sent!
Old 09-17-2010 | 07:49 AM
What's bulletproof???? No such thing exist. Everything ever built by man will eventually fail. It's a fack of life.
John the Drive Man is offline
Old 09-29-2010 | 11:17 AM
I don't think the tranny will be the weak link -- you can build them to hold just about any power within reason that you will put into a 24 ft boat.
with that said the TRS will handle 600 hp if treated with respect, if you are going to have more than 600 hp in a 24 you might look into a konrad-- good to about 750/ 800. After that i'd look into an arneson surface drive.
Sounds like it's going to move!
delsol is offline
Old 10-06-2010 | 10:11 PM
Registered User
Default Trs Drive
Will the speed master 11 really bolt to the TRS drives. Will it slow the boat down!!!! My lower skegs are really beat up. I want to get new low units or buy something better.
sdrockslangers is offline
