Busted Bravo 1 XR
Old 09-16-2010 | 02:09 PM
Default Busted Bravo 1 XR
I don't have it apart yet to see how bad; but, I broke the drive last weekend at the Cumberland Poker Run. Assuming I haven't destroyed the case and just need gears and bearings, anyone had any luck with XR upgrades? Sources for these parts?
Thanks,
Mike
Hot Tub is offline
Old 09-16-2010 | 02:36 PM
t500hps's Avatar
21 and 42 footers
FYI: I have a XR sitting in the garage with new upper (never bolted to a boat), gears, bearings, and fresh rebuilt lower. Looks new. Sold the boat and looking to get it out of the garage. $4,500 pallet shipped.
t500hps is offline
Old 09-16-2010 | 02:53 PM
Quinlan's Avatar
What ratio? and Swept back or not?
Quinlan is offline
Old 09-16-2010 | 05:32 PM
Thanks,
Mike
Did it sound like rocks in a blender when it went?
from my experiences, you'll need a compete upper.
If you just hit rev limiter and no painful noise, it
might have lucked out with a twisted shaft or sheared
the cone off the gear.
Unfortunately, merc is the only one who makes the gears. ( others market them)
There are others out there that do upgrades on the rest of it.
JaayTeee is offline
Old 09-16-2010 | 07:38 PM
It's hard to say exactly what happen. We were running down the lake at @ 71 MPH; came off plane and idled around - sounded fine. Came back up on plane and it sounded like the engine wasn't running right. Dropped off plane and idled around again; couldn't hear anything with the engine; but, when I put in reverse, got a noise liike a rod knocking - wasn't. Shut down and watched the big boys go by. When I tried to restart, it sounded like I stripped something in the starter; solenoid engaged and starter spun; but, engine didn't turn over. Towed back to State Dock. Didn't find out the drive busted until we pulled it out on Sunday and I spun the prop by hand - gravel. Guess I won't know how bad until I pull the top cap or more.
Hot Tub is offline
Old 09-27-2010 | 07:31 AM
Thanks,
Mike
Billet Marine built mine, very nice work and running them on my 37 A/T with big whipple motors and not easy on the sticks, zero failure.
laszlo01 is offline
Old 09-27-2010 | 06:36 PM
RICHARD CUNY's Avatar
HEY HOT TUB
I had a 24 sport with 650 hp ITS XR Imco shortie broke it all the time twisted shafts broke grars and upper housing,traded boat for a twin b1s no problem same hp on each. The singel just takes a beating with no help from another, and too,much air.
Rich
WATCHUS
RICHARD CUNY is offline
Old 09-28-2010 | 09:17 AM
Cobra Power
Default we have all the parts
hi if you want to fix it we have all the parts also we can fix it for you and guarantee our work call me at COBRA POWER 305-893-5018 thanks, Alex
cobrapower is offline
