Livorsi GPS Antenna "Yellowing".... >
Old 09-16-2010 | 08:18 PM
Default Livorsi GPS Antenna "Yellowing"....
My round plastic Livorsi GPS antenna is starting to discolor to a yellow color. Is there any product that will return it to white?
Thx-
X-Driver is offline
Old 09-18-2010 | 08:39 PM
Smitty's Avatar
Unfortunately no.. The sun is changing the color due to UV rays. All you can do is paint it white or whatever other color you want.
Smitty is offline
Old 09-18-2010 | 08:51 PM
Default Yup...
just tape it off, and paint it. The paint won't discolor like the white plastic did. An appliance white epoxy spray from Lowes/Home Depot will do the trick.
CanDo is offline
Old 09-19-2010 | 07:06 PM
Yellowing may be the lease of your worries. I found out this summer that the Livorsi system uses an antenna with an internal battery that is not replaceable and only lasts 4-5 years. For only @ $200 they can sell you a new style antenna... if you have the correct vintage speedometer head. Good luck.
Inspector is offline
Old 09-19-2010 | 08:14 PM
Turbojack's Avatar
Do a search on here. There is a thread about how to go about replacing the battery.
Turbojack is offline
Old 09-19-2010 | 08:23 PM
INDY27's Avatar
Just replaced the battery in mine, read this....
http://www.offshoreonly.com/forums/g...-speedo-3.html
AUTOCONNECTIONLLC.COM
INDY27 is offline
