Top Mount Stater Guys >
Old 09-18-2010 | 09:32 AM
Default Top Mount Stater Guys
Any one on here have a top mount starter. Mine are kind of loud to me. Has anyone had to shim them just looking for some feedback.
Car Biz is offline
Old 09-18-2010 | 09:38 AM
have top mounts and never used any shims ,may want to check the bellhousing & flywheel
good luck
Old 09-18-2010 | 02:52 PM
good luck
RH- check what on the bellhousing? the flywheels are are good the motors were just done last fall.
Car Biz is offline
Old 09-18-2010 | 03:04 PM
Check the mating service service where starter meets bellhousing
Old 09-18-2010 | 04:15 PM
bwd
I've had that prob before. There are a couple different types of starter gears (or drives). I can't give you details cause I don't remember which is which. The same old story in this country, Not much is made here with pride anymore.
bwd is offline
Old 09-18-2010 | 04:18 PM
U CANT STICK A 168 TOOTH STARTER ON A 152 TOOTH RINGGEAR...maybe that helps ?!!!!!
DareDevil is offline
Old 09-18-2010 | 06:09 PM
Rookie's Avatar
I have a spare starter in my boat if you want to try it. I just had it rebuilt for $45. There is a guy over on Alpine across from the old lear plant that rebuilds them inexpensively. He does all my starters and alternators. He is in front of the Butch's Total Car Care building.
Rookie is offline
Old 09-18-2010 | 06:19 PM
Brad Zastrow's Avatar
If you have offshore motor mounts between the block and bellhousing you should use a "cut" bellhousing for the starter to match up to ring gear. Maybe that is an issue?
Brad Zastrow is offline
Old 09-18-2010 | 08:18 PM
spazboz's Avatar
That was my thought too. Or as said earlier, if something is prohibiting the starter from completely seating in its bore squarely.
spazboz is offline
Old 09-20-2010 | 11:34 AM
Brad i do not have offshore mounts the mounts are bolted the trans i am running Twin Disc MG502 trans here is a pic
Car Biz is offline
