bravo III
I have recently discovered a ticking noise in Bravo III outdrive. It sounds like a metalic tick and you can also feel it if you touch the outside of the outdrive. This is a new noise. I does it in neutral and in gear. Any Ideas?
I would check the simple stuff first. Pull the drive and inspect the u-joints for wear. While you have the drive off, put your hand up into the bell housing and spin the gimbal bearing with a couple of fingers. Make sure it spins nice and smooth. If all that checks out then the drive might need to be torn down and inspect.
It's exactly the same as the B 1, but it wieghs quite a bit more. With props, over 200 lbs. It's doable with one person, but two will save your back.
