SHOGREN Performance Marine Winterization Tips
Sadly, it is the time of year for much of the country when performance boaters start the dreaded task of getting their boats ready for winter storage. Whether a boat is professionally winterized or the owner is a do-it-yourselfer, the award-winning service department at Shogren Performance Marine offers some helpful tips to get the most out of the process.
“Winterization not only protects a boat and engine from freeze damage, it also protects against long periods of sitting unused,” says Scott Shogren of Shogren Performance Marine, adding “It also makes for less prep time in the spring when you’re ready to get back on the water!”
Fuel Level :
Should be half to three-quarters full prior to winterization. This allows the correct amount of fuel stabilizer to be added and run through the entire fuel system as part of the process.
Fluids & Filters:
Both engine and drive gear oil and filters should be changed. Fresh fluids are always preferred for long-term storage. Water/ fuel separator filters should also be changed.
Flushing:
Engines should be flushed with a non-toxic antifreeze prior to winter storage to protect against any residual water that is left in the engine. The antifreeze has non-corrosive properties to help prevent against rust forming within the engine.
Batteries:
Fill the fluid levels in the batteries – if applicable – and have them fully charged with no draw before storage. Doing so allows batteries to remain in the boat all winter long and will be ready in the spring time with just a quick “top-off” charge.
ShrinkWrap:
Shrink Wrap is mandatory for outdoor storage to protect against the elements, but boats stored in unheated outbuildings should also be shrink wrapped to prevent rodents and other critters from making a warm winter’s nest.
“Don’t forget the freshwater system, head, air conditioner, hot water heater, shower sump and generator!” Shogren reminds owners, “They may have special winterization requirements to prevent damage” he adds.
In addition to winterization and other service, Shogren Performance Marine provides indoor, heated storage as well as boat transport to and from its facilities, a winter boating destination, or anywhere else an owner may need a boat to be moved. The service department at Shogren Performance Marine consistently finishes in the top tier of the Customer Satisfaction Index (as measured by Mercury Marine) and has the experience to handle any boat and motor combination.
Fuel Level :
Fluids & Filters:
Flushing:
Batteries:
ShrinkWrap:
Tanks better off empty,,,, you may get condensation in the tank that way, but it is the lesser of two evils these days.
I want to live in a world where a chicken can cross the road and not have its motives questioned.
150 gallon tank 3/4 full 112 gallons that sit 6-7 months in boat octane goes from 91 to 80 with water in it and in the spring running 112 gallons of wiesel fuel through a 500 + HP motor I can see problems waiting to happen with the shi$$y fuel in it . No way would i do it runem empty and put 150 fresh gallons in it in the spring.
I just bought a boat with 100 gallons of old fuel. put 100 of new fuel and alot of octane boost and still have problems.
My plan is to run it to close to empty, stablize it then dump some fresh fuel in come spring.
