496 EFI to carb >
496 EFI to carb
496 EFI to carb
Old 10-21-2010 | 02:29 PM
Default 496 EFI to carb
Posible to go from EFI to a carb on a 496 HO mag?
$800 to reflash the computer to help with the smutty black swim platform.
$800 will sure buy a nice carb, sell the ECM and it will pay for a full MSD set up.
Have not looked at the gaskets to see if the EFI intake has the same lay out.
Waterslinger is offline
Old 10-21-2010 | 02:41 PM
Default Fixx
what fuel are you running,,premimum fuel will do that..
FIXX is offline
Old 10-21-2010 | 02:51 PM
Tank full of 87 and it is crazy smutty.
496 head will not take a carb intake see pic CRAP
http://www.offshoreonly.com/classifi...o36335-en.html
Old 10-21-2010 | 04:26 PM
Default Fixx
i knew that one already you can have one made but by the time converting it all over and you will need a new ignition system also you may as well have it tuned..
FIXX is offline
Old 10-30-2010 | 04:56 PM
You just need to find a dealer or Mercury service tech who can reflash your PCM to a newer calibration. Newer cals are leaner and won't soot as much on your transom.
AmericanMuscle is offline
Old 10-30-2010 | 05:56 PM
also check fuel pressure,,,and pressuse regulator
TWIN-SPINS is offline
Old 10-31-2010 | 08:58 AM
I say leave it efi,
what year and is it a mag or a mag Ho?
I have a couple 555 ecus reflashed by merc with the sooting update from 2003 496 mags ,I would sell you on for half the cost of reflashing yours.
boatnt is offline
Old 11-01-2010 | 06:24 AM
its a 496 MAG HO think its a 03 or 04, has aluminum manifolds
think 05 is when Merc went to cast iron manifolds right?
