Replacing Oil Seal Behind Gimbal Bearing >
Old 05-11-2002 | 11:06 AM
blackhawk
Default Replacing Oil Seal Behind Gimbal Bearing
I am getting ready to replace the oil seal behind the gimbal bearing. The parts breakdown shows the seal going in flat side first. Is this correct? I would think since the outdrive shaft goes through the bearing and seal to the engine coupler, the flat side of the seal should be facing out. Please help! Thanks
Old 05-11-2002 | 01:07 PM
Raypanic's Avatar
I went through the same thing I pulled the old ones not looking at wich way they were. I ended up putting them in the way the parts manual shows flat side in first. I had to rig up a ram out of galvanized pipe parts to get it in. I used a 2" coupler with a 2" to 1" bushing, a lenth of 1" pipe and a cap. Also wrapped a little electrical tape arround the end to give it a snug fit that held the seal in place before driving in.
Ray
Raypanic is offline
Old 05-11-2002 | 01:13 PM
blackhawk
The problem with mine was I didn't take it out so I had no idea. But between the manual showing it that way and grease on only one side of the seal (which wasn't the flat part), I figured it must go that way. I just put mine in almost the same way. A 2" piece of PVC pipe and a block of wood.
Thanks for the reply. Now if I could figure out the engine alignment tool I'd be all set!
jdub
5
05-25-2006 07:10 PM
East Coast B
11
09-16-2005 06:50 AM
WetKitty42
3
06-02-2003 12:28 PM
THRILLSEEKER
3
10-15-2002 02:04 PM
imongo
2
08-15-2002 04:04 PM
