help SEAWATER PUMP??
Old 10-28-2010 | 08:46 AM
Default help SEAWATER PUMP??
BOAT IS A 1999 Baja 252 boss, 454mag.
Ok so take the boat to the coast and got some sand sucked up because of my bravo one outdrive is a performance version with a low water pick up. boat over heated, I caught it, and limped it to the trailer. I replaced the impeller, and the thermostat. Started working a little better, but would still slowly overheat. Got into some more sand, I KNOW but **** happens.
So I check things and the water lines were full of sand, so took everything apart, and back flushed it all, got everything cleaned out. checked pump everything is working.
Took it out that night worked great, then Sunday put about 60 miles on it in the ocean, Fort Walton to Sand Destin and back, then on the trailer.
Came home with the boat, and tried to flush it with fresh water and it over heats. So I check everything and it’s not sucking the water up, so I take all the hoses off again, and check and everything is clear. Then hook up the seawater pump to the out drive and started the motor, with the output hose on the back of the pump disconnected. no water coming out......pump spins with the shaft when you turn the pulley, blades look fine (only 2 days old), but yet not working when it did 2 days ago.
IDEAS?
mittens is offline
Old 10-28-2010 | 09:03 AM
if its a plastic pump housing it may be broke inside.
lightning jet is offline
Old 10-28-2010 | 09:49 AM
its a plastic houseing, why would it work one day and not the next?
mittens is offline
Old 10-28-2010 | 09:59 AM
HotSpare's Avatar
check for restrictions between pump and lower raw pickup, especially in hose between pump and transom ..... Also pump impeller (if plastic pump with rubber impeller) could be fried again from running dry .... Thats all there is, if nothing's coming out of the pump ..... Good Luck ... Keep us posted .....
HotSpare is offline
Old 10-28-2010 | 10:06 AM
HotSpare's Avatar
HotSpare is offline
Old 10-28-2010 | 10:14 AM
yep pulled all the hoses and from the pump to the water pick up is clear, can runa hose of water through it solid.
pump empellar is 2 days old and worked geat, not does nothing.
mittens is offline
Old 10-28-2010 | 10:40 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
I've had a set of muffs that would not work no matter what I did. I used them for a couple yrs no problem, then one day nothing.
US1 Fountain is offline
Old 10-28-2010 | 08:35 PM
carter38's Avatar
I bet the plastic housing is pretty wore if it had sand in it. If they don't seal off they won't pump.
carter38 is offline
Old 10-28-2010 | 09:45 PM
If the plastic housing has a crack in it and is sucking air it won't pump either. Just something to check
CMG223 is offline
Old 10-28-2010 | 11:05 PM
If you have flushed and checked all the lines to the pump and disconnected the hose coming out of the pump with no luck then about all you can do at this point is take it back apart for a through inspection. Check for deep grooves worn in the plastic pump body. If it does have grooves it will wear the new impeller to the grooves. They actually sell impeller kits with the pump body and wear plate beings they wear out so fast.http://www.go2marine.com/product.do?no=77502F
You didn't by chance have both hoses off the pump at one point and accidently put them back on wrong did ya? Sounds like you know what your doing. Keep at it , you'll get it.
picklenjim is offline
