Floating Trailer
Old 10-28-2010 | 09:09 AM
RICHARD CUNY's Avatar
Default Floating Trailer
I have a triple axle trailer that floats only on one side when put in deep how do I correct this and any one have the same problem.
Rich
WATCHUS
RICHARD CUNY is offline
Old 10-28-2010 | 09:15 AM
damdonzi's Avatar
http://www.offshoreonly.com/forums/g...-syndrome.html
damdonzi is offline
Old 10-28-2010 | 09:26 AM
people actually have problems with floating trailers...WOW
how heavy is the trailer that it floats in water?!?!? that is nuts
1MOSES1 is offline
Old 10-28-2010 | 10:18 AM
rchevelle71's Avatar
Usually an aluminum trailer with Aluminum wheel, in salt water(more buoyant). Believe it or not, the Aluminum trailers are quite light when empty. Mine even has Aluminum Bunks
rchevelle71 is offline
Old 10-28-2010 | 10:23 AM
I see it a lot. It usually depends on the tires. Have had some that didn't float until the customer went to just a little larger tire combo and them it floated. Makes loading fun. I have a customer that used John Deere tractor weights to stop it from floating. He made some small brackets on the rear of the trailer to make them removable. They just slipped over the bracket when launching. You could also fill some pvc pipe with concrete and strap it to the trailer. Several ways to fix it.
Eddie
Young Performance is offline
Old 10-28-2010 | 02:39 PM
Frequency's Avatar
Eddie,
When the Envision sold I forgot about the weights, they're still in the garage. Now that I know how much you miss them I'll drop them off when I pick up the Cafe.
Frequency is offline
Old 10-28-2010 | 06:09 PM
Thanks for all the input my trailer only floats on one side causing the boat to load out of center at the stern. I will try weight next year.
Rich
WATCHUS
Old 10-28-2010 | 06:23 PM
LapseofReason's Avatar
Just put more #'s of air in the tires so they will weigh more and will sink.
Just Kidding
LapseofReason is offline
Old 10-28-2010 | 07:51 PM
mine floated and I found it easier to load, it floated level though, I can imagine one side floating would be a *****
Pete280 is offline
Old 10-28-2010 | 10:20 PM
I was about to suggest strapping water tank to the trailer for weight, but the add extra psi to the tires for weight is a better idea....
Chart is offline
