How hard do you normaly run your engine >
Old 10-28-2010 | 07:23 PM
Default How hard do you normaly run your engine
I was curious on what rpm evryone runs there boats most time. Do you run 3000, 3200,3500,3800,4000 for cruise rpms.
If you like, list a general idea of your boat and how you run it.
I have a
30 cig mystique
496 ho
cruise 3500 @50 mph normally
fast cruise 3800 to 4000.
Allicat38 is offline
Old 10-28-2010 | 07:26 PM
the 38 ocean yacht
3208 diesel
2300-2400 @22knts normally
full out at 2800 @27 knts
Old 10-28-2010 | 08:09 PM
Rookie's Avatar
Scarab Panther
Cruise: 3700 RPM 58mph that is right before my 4barrels kick open.
WFO: Almost 80 around 6000RPM
600HP 454's Still trying props
Rookie is offline
29' Kryptonite
598ci N/A 750hp
Cruise usually at between 3500-4000rpm, 52-60mph
WOT 6000rpm at 97mph
Philm is offline
Old 10-28-2010 | 08:13 PM
Single 496 HO with Raylar, 26 Bravo 1 4300rpm @ 52 mph.
verbi69 is offline
Old 10-28-2010 | 08:14 PM
5300 rpm wo @ 74 mph gps
verbi69 is offline
Old 10-28-2010 | 08:18 PM
Default Fixx
donzi x18
24p prop
half throttle just before the secondarys
5000 rpm's 60 mph
max rpms 6200
in the 70's
26p prop heavy cup
3800 rpms 50 mph
FIXX is offline
Old 10-28-2010 | 08:20 PM
Strip Poker 388's Avatar
Rob
I normally run 3200 to 3400
it starts to hit boost about 3900-4000
38 Hustler 868hp at 6000rpm
Strip Poker 388 is offline
Old 10-28-2010 | 08:21 PM
seafordguy's Avatar
When I am not idling I spend about 95% of the time in the 33-3600 RPM range.
seafordguy is offline
Old 10-28-2010 | 08:49 PM
27ft Carrera, 509" around 525-550hp ,
Bravo drive with nosecone, 26p Powertech,
fully loaded weight around 6000lbs
cruise 4000rpm 45-47 mph
WOT 5200rpm 69-70mph
due to high x dimension ,
single engine,no tabs,
25deg V and heavy boat it wont even stay on plane below 3400rpm..
for me its idle or 35mph..
Hopefully I can fix that with a 5 blader.
HTRDLNCN is offline
