Swing away trailer tongue…. >
Swing away trailer tongue?.
Old 11-01-2010 | 08:01 PM
dogghouse's Avatar
Default Swing away trailer tongue….
This may be a crazy idea but I’m just going to toss it out there so you guys can tell me what y’all think.
I have a 36 Spectre and on the trailer it’s a little to long to fit in my shop. I can always extend my shop and I’m not apposed to that but if I can install this tongue it will save me a good bit of money.
Will it work?
-Nate
dogghouse is offline
Old 11-01-2010 | 09:27 PM
Will it work?
-Nate
Never seen one on a trailer that large, and I doubt a pivot would be safe.
You might be able to make a sliding tongue. (similar concept like the hydraulic trailers the marina's use for multiple boats)
2Slow4me is offline
Old 11-01-2010 | 09:38 PM
jayboat's Avatar
Default No!
Does not sound like a good idea AT ALL. Think about all the force applied at that joint with a 10,000 lb boat bouncing along at highway speed.
Had a buddy back in NC with a Fountain CC- trailer was 18" longer than his garage. He cut a notch about 4" wide out of the garage door and let it hang out. Worked fine.
Roostertail does not lie.
NAPLES IMAGE Photo Galleries
jayboat is offline
Old 11-01-2010 | 09:40 PM
Sent you PM..
MiniHawk is offline
Old 11-01-2010 | 10:20 PM
X-Rated30's Avatar
It would depend on the trailer. A good engineer could make a pivot for most trailers that would make the rest of the trailer the weak link. That being said, cost will become an issue. You might also want to consider aesthetics and ease of use.
X-Rated30 is offline
Old 11-01-2010 | 10:34 PM
Audiofn's Avatar
Charter Member #232
Can you slide the boat up on the trailer, then move the bunks and axels forward and then cut off the extra off the back?
Put your best foot forward!
Audiofn is offline
Old 11-01-2010 | 10:35 PM
dogghouse's Avatar
Originally Posted by MiniHawk
Sent you PM..
I did not get your PM.... my email is [email protected]
Old 11-01-2010 | 10:37 PM
dogghouse's Avatar
I had a idea something like that also.... I can only go up about 2ft. I need 3ft.
Old 11-02-2010 | 01:24 AM
I don't think it can be done safely for a trailer that large. I would just extend the shop.
Griff is offline
Old 11-02-2010 | 02:22 AM
Audiofn's Avatar
Charter Member #232
Why can you only go up 2 feet? Can you get a picture of the front of the trailer up?
Audiofn is offline
