why doesnt most cats have trim tabs? >
Old 11-08-2010 | 10:10 AM
Default why doesnt most cats have trim tabs?
Outkast Rafe is offline
Old 11-08-2010 | 10:12 AM
Ted G's Avatar
By nature cats tend to run flat from side to side because of the air cushion in the tunnel, and the tabs typically won't have near the effect on angle of attack that a tunnel tab will for that same reason. So if they need trim that the drives can't provide a tunnel tab makes more sense.
www.cbpba.com
Ted G is offline
Old 11-08-2010 | 10:52 AM
glassdave's Avatar
Neno the mind boggler
Yep. . . . . . What Ted said. We have them on the race boat and I have never used them once. Tunnel tab comes in handy once in a while though.
08 OPA High Points Champion
glassdave is offline
Old 11-08-2010 | 10:55 AM
They dont need trims but if you dont have one in the tunnel good luck gettin on plane....
antisocial is offline
Old 11-08-2010 | 11:18 AM
i see
thanks
Old 11-08-2010 | 12:08 PM
Not all cats need or would benefit from a tunnel tab.
Mine gets on plane just fine without a tunnel tab.
I do use my trim tabs a small amount in rougher conditions
stainless is offline
Old 11-08-2010 | 12:20 PM
what is tunnel tabs? any pics?
Old 11-08-2010 | 12:24 PM
i think it is a large tab between the 2 hulls ?? paul
paul buckner is offline
Old 11-08-2010 | 12:31 PM
Too Stroked's Avatar
A Tunnel Tab looks like a giant Trim Tab mounted at the rear of the tunnel between the sponsons. It re-directs air more so than water because of it's location. Drop it down and you pack more air in the tunnel - which gives you more lift. On a center pod tunnel (Eliminator cats for instance), it works more like a single Trim Tab.
Too Stroked is offline
Old 11-08-2010 | 12:36 PM
oh yes ive seen one of these before on a American Offshore i think
