Molding steps for dash
Old 11-12-2010 | 11:01 AM
Default Molding steps for dash
Ok, I've had trouble before getting up to the bow... I'm not as young and agile as I used to be so I need some better steps added in.
What I'm thinking about now is cutting the glove box out and starting over from the ground up. I would first use cardboard to mock up the whole construct, then make it out of wood for strength and glass over it. If I don't cut the glovebox out then the steps would go too deep between the seats.
Anyone have cool ideas how to implement this feature?
Attached Thumbnails Molding steps for dash-dash-view-where-steps-need-go.jpg   Molding steps for dash-great-step-design.jpg
jackhammer is offline
Old 11-13-2010 | 11:36 AM
I don't know how young you are, but it may be worth it to just glass in the whole front flat to the floor, put a step in the glove box, and put a grab handle/aluminum step/something bolt on (and perhaps flip-up to get it out of the way when you don't need it). That would save you from needing any elaborate mold, and probably save a TON of work (and it should look good too!).
Personally I find the best solution is to keep an early 20's girl on board. I generally anchor at the helm, hand her the rope and have her tie it off to the front cleat...
wjb21ndtown is offline
Old 11-14-2010 | 10:21 AM
I like the way you think!
I could easily incorporate something like this...
http://www.bustin-usa.com/products/t...flipupStep.php
Old 11-14-2010 | 11:58 AM
What about steps molded into the cabin door such as a Cig has?
ttuton is offline
Old 11-14-2010 | 04:33 PM
c_deezy's Avatar
The flip-down steps like you see on the back of firetrucks might work too.
c_deezy is offline
Old 11-15-2010 | 01:11 AM
http://www.danamarineproducts.com/Pr...4-667f2a3724ab
Griff is offline
