Header welding in Michigan? >
Old 11-13-2010 | 06:22 PM
Default Header welding in Michigan?
I have a set of CMI E tops that have three leaks I need fixed. One in the head flange and 2 in the collector. I'm in Northern Michigan and am looking for someone good that can fix these right! Any suggestions? Anyone know if Valako does this?
endeavour32 is offline
Old 11-13-2010 | 07:56 PM
OL40SVX's Avatar
If you want to ship them to CT we can fix them right.
OL40SVX is offline
Old 11-13-2010 | 10:49 PM
Default Fixx
send them to cmi,,if they leak then who to blame..
FIXX is offline
Old 11-14-2010 | 12:58 PM
Rookie's Avatar
Jim has a TIG and I have seen him weld some exhaust, give him a call.
Rookie is offline
Old 11-15-2010 | 11:57 PM
Know anyone in MI that can presure test CMI's? I'm not sold on sending them back to CMI as I had a friend have to resend them 3 times to get them finally fixed.
Irishtornado is offline
Old 11-16-2010 | 12:22 AM
You can test them yourself. Eddie Young in the second post explains how to do it.
http://www.offshoreonly.com/forums/g...r-testing.html
Old 11-16-2010 | 07:36 AM
JimV's Avatar
Yes sir, I can weld them if they are cracked in the flange area or in the collector. If they leak in the primary tube you may have to send them to cmi to be cut and welded $$. I pressure check them before and after. JimV
JimV is offline
