Need more stern lift
Still paying with props on my 22 Center Console and need more stern lift. I have a 24 pitch stock Bravo One that works well but runs a little nose high. What style prop would give me the best stern lift? This is an outboard application.
I like the Q4. Also, a slightly modified P5X could work great if mid range cruise is the main goal. (We would decrease the diameter and blade area)
Brett
Brett
[email protected]
[email protected]
The Q4 will pull the R's down slightly due to truer pitch and wetting more of the hull. So, use that and your current rpm to decide.
Brett
Brett
[email protected]
[email protected]
A touch smaller in diameter with 5 degrees more rake angle (bow lift). Also the cupping is a little stiffer. The Rev 4 will give better overall lift where as the Q4 will give better stern lift.
Why not test them? Call us and we can arrange this.
Brett
Brett
[email protected]
[email protected]
