Question about Holley rebuild kits >
Old 12-01-2010 | 10:20 AM
Default Question about Holley rebuild kits
Hello,
Rookie question here- I'm looking for a carb rebuild kit for the Holley 9022 that was used on the Merc 465/502's.
Does anyone know what the difference between the "regular" rebuild kit and Holley's marine rebuild kit? The parts guy I spoke with said the marine kit has the green accelerator pump diaphragms that are designed for use with fuels that contain alcohol, couldn't give me any other details.
Is there anything special in the marine kit that is needed or can I use the standard rebuild kit? (one kit is in stock, other has to be ordered)
Renew kits I was looking at-
standard- Holley 03-1184, AED 4150
marine- Holley 03-485
Thanks in advance,
Rick
Powerquest230 is offline
Old 12-01-2010 | 12:04 PM
don't think there is any difference between the (regular) and
the marine kit wise, most reg kits come w/the "green" pumps
now anyways
blownjet 468 is offline
Old 12-01-2010 | 01:03 PM
I've seen kits to change a few things and set the carbs up for ethanol use. Might be worth looking into if your going to rebuild it anyways.
TexomaPowerboater is offline
Old 12-01-2010 | 01:36 PM
They should be within $20 of each other, buy the marine kit. Everyone I know that's tried to use a non-marine something in a marine application (unless it was a Mercruiser brand something and GM, Felpro, or otherwise made the EXACT SAME PART), only to save 10-20% on the cost of the item, ended up regretting it. If you buy the marine kit you know that you should be good for a number of years with the carb. If you buy something automotive and try to use it in the marine app. who knows how long it will be good for, who knows where it will leave you stranded, and who knows what else it will effect???
Just my $0.02
wjb21ndtown is offline
Old 12-02-2010 | 09:06 PM
Price of the kits wasn't an issue ($15) it was availability. I used AED's 4150 kit and the only pieces that needed to be changed were the power valve, and the accelerator pump diaphragms. Kit comes with 6.5 power valves(needed a 4.5) and 30 & 50 cc pumps (need 2 50's).
Thanks for the help,
Rick
