tall deck vs. short deck exhaust holes in transom
No one else seems to have an answer for you. So I will tell you that it is approximately less than .5 inch taller and wider. My boat has had both and the headers and tails fit with both short and tall. Probably a way that you can fudge without major changes. Really not a lot of difference. Hope it helps.
It really depends on what pipes you have. The shorter they are, the harder it is to make them fit. The collector will move out about 3/8" and up about 3/8". That is assuming you are using the same heads. Some heads have raised exhaust ports. They can be raised as much as .600"
Eddie
Eddie
Eddie
Eddie
Do Dart Pro1 heads have the raised exhaust ports?
As mentioned, Dart Pro 1's do have raised ports.
Eddie
