What fuel pump for a GenV >
Old 12-05-2010 | 09:38 PM
Default What fuel pump for a GenV
What is a good fuel pump for a genv that runs off of the water pump. I was looking to replace the original merc pump with a holley or something similar.
still smoking is offline
Old 12-05-2010 | 10:01 PM
That is not the same mechanical pump as a standard Chevy pump. The arm on that pump is different than a standard pump, so you have to use a Merc. style pump. However, you can replace just the lower pump section of your existing pump. CP Performance has a real nice pump section.
http://www.cpperformance.com/p-12460...6-engines.aspx
Hope this helps.
Eddie
Young Performance is offline
Old 12-06-2010 | 06:28 AM
Thank you that was what I was wanting to know.
Old 12-06-2010 | 10:32 AM
Glad I could help.
Eddie
Old 12-06-2010 | 11:51 AM
billeickmann's Avatar
Default fuel pump for EFI
While on the fuel pump issue, what would you suggest for a 2000 500EFI with an electric pump only? Stay with Merc or go aftermarket?
billeickmann is offline
Old 12-06-2010 | 07:02 PM
I would stick with the electric Merc pump in your case. It will be much easier and cheaper in the long run to stay with the stocker. If you go aftermarket, then you will need to redo quite a bit of plumbing to make it work.
Eddie
Old 12-07-2010 | 06:29 PM
Hope this helps.
Eddie
I have been running one of those for four seasons now, It is a good pump to upgrade to.
Old Navy is offline
