Pneumatic Fuel offloading pump?
I am looking for a pump that I can attach to my air compressor to safely pump the fuel out of my boat.
I've done a little digging, but I don't really know what's good and what's crap.
Can anyone recommend one?
Thanks in advance.
Thanks in advance.
Run a pickup tube to the bottom of the barrel and attach the hose to that. Put an air fitting on top of the container. Seal it all up and air up the container with a couple of pounds pressure, it will push all the fuel out.
A couple people have suggested using something like this:
http://www.mr-gasket.com/ProductDeta...minselection=1
...attached to a car battery or jump box.
I was hoping to take advantage of my air compressor for a little additional safety, (whole electric/fuel thing wigs me out).
But the suggested systems have worked well for others so I'll give this a try.
Thanks for the PMs gents.
http://www.globalindustrial.com/g/ma...s/rotary-pumps
We used them on the farm all the time, works both ways as syphon and pump.
We use electric fuel pumps all the time to empty the raceboats out, just make sure you have a solid connection to the battery(no sparking), and keep the battery above the fuel lines, or at least far enough away so that if there is a spill it will not contact the battery or cables.
I made a setup for fuel transfer and it is a carter ele fuel pump mounted on a board. It has a battery on the bottom with a spark proof switch. Has 25' pickup hose that can go to the pickup on the tank or down the filler. I use 3/8 plastic tubing. It goes into a clear fuel filter as to see what's moving through it. The discharge side is connected to a 1/2 fuel hose also 25'. It pumps 75 gph. I can email you picts if you like.
As for the rotary pumps they don't seem to hold up pumping gas.
