Go Back  Offshoreonly.com > Owners Forum > Eliminator
23 Daytona ? >
23 Daytona ?
23 Daytona ?
Old 12-07-2010 | 12:22 AM
Default 23 Daytona ?
I have a 88 23 Daytona with the standard offset brackets. The boat has a pair of OMC 20" mids that are mounted as high up as I could get them. My question is can I run a pair of Merc 15" mids if bolted all the way to the lowest position.
Thanks,
James
hwyrnr is offline
Old 03-28-2011 | 03:50 AM
need help with my question time to decide to rebuild motors or go with 15"
hwyrnr is offline
Old 08-10-2011 | 08:52 PM
Stay with 20". 15's will go under water when comming off plane. Put on a set of hydrolic jack plates so you can raise to where you need when running.
perfmarine1 is offline
Old 05-04-2012 | 07:10 PM
plus 1 i owned one 15 mids are to small for that boat
mach1magnum is offline
