Need Props cleaned >
Need Props cleaned
Need Props cleaned
Old 12-09-2010 | 01:32 PM
Default Need Props cleaned
After leaving my boat in the water during Key West Run, i pulled it out and my props are almost completly covered. Any easy off items I can use to get them back. I dont really have the time to scrub them. Thanks,
Mykalvballer is offline
Old 12-09-2010 | 03:11 PM
teaguecustommarine's Avatar
Offshoreonly Advertiser
I use industrial strength Toilet Bowl Cleaner or Simple Green.. Either work pretty good. Pull the prop/s off and lay in sink, spray on, rub in with your hands, let sit for a few minutes and wash off well. Do not sand or use a scotchbrite.. -Eric
TEAGUE CUSTOM MARINE
661.295.7000
www.teaguecustommarine.com
teaguecustommarine is offline
Old 12-09-2010 | 04:19 PM
Brad Zastrow's Avatar
Agreed.
Brad Zastrow is offline
Old 12-09-2010 | 04:27 PM
roll off and magic erasers?
Perlmudder is offline
Old 12-09-2010 | 04:34 PM
Hoosier metal polish , spray it on & polish em up
Old 12-09-2010 | 09:38 PM
Just use some acidic type of toilet bowl cleaner or lime away.
Griff is offline
Old 12-10-2010 | 08:03 AM
Just about any toliet bowl cleaner. I use on the exhaust tips too.....no elbow grease at all.
Baja_man is offline
Old 12-11-2010 | 04:21 PM
I use "aluminum brightener" available from Napa, but like said
before, any acid based cleaner should work
blownjet 468 is offline
Old 12-11-2010 | 09:07 PM
1% muriatic acid solution rinse off extremely well works good on hulls too just as long as they dont have zinc or copper based bottom paint
Centsless is offline
Old 12-29-2010 | 08:22 AM
T-Bowl cleaner worked perfect. Took everything off... Spray on and rinse it right off.
