502 with M1sc >
502 with M1sc
502 with M1sc
Old 12-14-2010 | 10:32 AM
Default 502 with M1 SC Procharger
Well it looks like my 99 OL25is gonna get the M1 put on. Just picked one up that has the crossovers, and regulator with it but no fuel pump. Thinking the aeromotive pump is the one I want.
I have read that new fuel line right from the tank are needed?
Motor is stock with 230 hours and stainless marine exhaust and am not looking for crazy speed just want the boat to run over 70 even if I have a full tank of fuel and 5 passengers.
A few questions...
Does the ECM need anything
Any other fuel requirements
Also, what about thermostat? Boat run 180 degs now
Any other tips would be great.
kragar is offline
Old 12-14-2010 | 10:44 AM
A few questions...
Aeromotive pump.
New 1/2"min line from tank
no thermostat
ecm recalibration.
Upgraded oil cooler if you want it to live!!
kennyo is offline
Old 12-14-2010 | 11:06 AM
What is done to the ECM? Timing taken out?
kragar is offline
Old 12-14-2010 | 11:38 AM
More fuel
4bus is offline
Old 12-14-2010 | 12:14 PM
Default Fixx
Contact mark boos for the ecm calibration..he has some calibrations for your set up..
Precision Marine, Inc.
2238 Richland St.
Kenner, Louisiana 70062
504-469-7463
FIXX is offline
Old 12-14-2010 | 01:28 PM
How come on the procharger site, they dont talk about sending your ECM out for a new curve? Do they just use the regulator as a band-aide.
kragar is offline
Old 12-14-2010 | 02:27 PM
Default Fixx
yep its just a bandade,if you take the thermostat out your engine wont know its warm and it will stay in cold mode and the idle wont come down,that's one of the things that need to be addressed..call mark,he knows what needs to be done..
FIXX is offline
Old 12-14-2010 | 03:59 PM
fixes it right up till a piston exits the game....
ezstriper is offline
Old 12-14-2010 | 06:14 PM
Default Fixx
Also,look into a 2 bar map sensor also,,sopppose to clean up the FI a Bit,it will have to be calibrated into the ecm,and raise the rev limiter,prochargers like rpm...if done correctly you will pick up 10+ mph with the rite prop..i have seen guys run into the 90's on 22 classics..
FIXX is offline
Old 12-14-2010 | 07:36 PM
Pro Charger has a habit of forgetting to share all the little details that you need to do !!!! And calling them will just be a waste of your time . Lucky for you that there are a few engine guy's on this site that will usually offer their help. Good luck Jeff
Jeff P31 is offline
