Trim Tabs What Size?
Old 12-24-2010 | 08:44 AM
scottw's Avatar
Default Trim Tabs What Size?
On a 24' hull with 21* deadrise, what size tabs?
scottw is offline
Old 12-24-2010 | 10:30 AM
Too Stroked's Avatar
What kind of weight, power, speed and intended use are we talking here? Do you need them to help get up on plane or are you looking to control the attitude the boat flies at better?
Too Stroked is offline
Old 12-24-2010 | 10:52 AM
Some dual ram Bennets should be enough, but if you want something better, then 280 Kplanes.
Griff is offline
Old 12-24-2010 | 01:43 PM
scottw's Avatar
Boat weighs in at 4300lbs. full of fuel and gear. Will be in the 600hp range after rebuild and should run near 80mph possibly a little over. Run boat in the Atlantic Ocean, local rivers and Chesapeake Bay. Boat gets on plane fine and with the power I have now which is only 385hp the boat runs with a good attitude.
scottw is offline
Old 12-24-2010 | 01:46 PM
scottw's Avatar
Kplanes are probably out of the budget. I was checking out some Lenco High Performance Trim Tabs. Was wondering on a length.
http://www.lencomarine.com/highperformancet.html
scottw is offline
Old 12-24-2010 | 01:57 PM
Steve 1's Avatar
I would run a long tab on it.
Steve 1 is offline
Old 12-24-2010 | 02:26 PM
scarabman's Avatar
Might be able to find a decent used set of K-planes for what the Lencos cost new?
What happened with the 28 Pantera?
scarabman is offline
Old 12-24-2010 | 03:16 PM
The bigger the better.
I have a 21' Revolution here in oz and i run the Dana HP 1100.
They made an already awsome boat leagues better.
Dont skimp on length!!
Kurt Hamilton is offline
Old 12-24-2010 | 03:29 PM
Lencos are nice tabs and easy to install. I do find their actuation to be a bit fast, but one can get used to it.
Dual ram Bennett Sport Tabs aren't bad, but more of a paint to install.
Boat Leveler makes a heavy duty tab, but the hose mount to the cylinders is problematic without some re-work.
K-Planes are awesome, but so is their price.
As for size, don't scrimp. I'd go 12"x12" minimum and longer if at all possible. Remember, trim tabs can effectively lengthen your hull by the length of the tab - which is usually cheaper than buying a longer hull.
When you do select your tabs, make sure you do some reading on how to mount them. Lots of posts here if you search. Mounting them incorrectly is not only a paint to fix, but will rob you of speed.
Old 12-24-2010 | 08:59 PM
scottw's Avatar
Just weighing my options on what I want to do on cost. Do I really want a payment on that boat or upgrade the one I have. The Pantera although a nice boat doesn't have the power I would wish for and with the payment I would have, it would take a while to upgrade the power.
scottw is offline
