280 bimini
this place is dead, need to wake it up a little.
Not really thrilled about the idea of drilling holes, but the anchor shade doesn't really work for us either, so I need to install a bimini.
Was curious if anyone has one installed one on their velocity, and if so if you have pictures of the mounts?
This is not only for shade, but I will fab up some side, front, and rear windows for rain, and bad weather when we overnight.
It will store in the engie comparment, I have plenty of room in there, and I'm not worried about using it while running either, mainly used for when we are anchored out.
I'm working on that for my boat too--I want to create a greenhouse effect to extend my boating season into cooler weather, as well as have a rain cover and sun shade. I ordered an 8 ft long bimini that comes with both vertical and horzontal mounts for the main poles. The width fits just inside of the cockpit. I'm going to try to use the vertical mounts and attach them onto the interior viniyl upholstry sides. Then, I want to make clear side curtains all-around like you mentioned...
Suntimes- I'd recommend using a solid mounting surface, use good stainless hardware and thru-bolt using backing plates not just washers whether your mount on the top of or sides of panels.
A Bimini was a great addition - really appreciated it with all of our no wake zones especially in August. The only downside we have noticed is that when the top is open or even closed up in the boot but in the upright position entry from the dock into the boat is a little more challenging. Our Bimini stretches from about 12" forward of the instrument panel to about 12" past the rear seat headrests so a smaller top may be less challenging.
Unless the weather forecast changes I should be able to take some pictures on Thursday or Friday.
Rick
Rick
Rick
Rick
Thanks for the pics.
It will probably be a little while yet, before I go for the windshield. How much would you take for it, and why are you selling it?
I can't decide if i would rather have the windshield or the windscreen.
