Speakers / most powerful
Old 01-05-2011 | 09:20 AM
OCDACTIVE's Avatar
A.T. Cult Member #4
Default Speakers / most powerful
I am thinking of adding two more speakers to my boat. They would most likely have their own amplifier and would need to be standard size. 6 inch I think??
Any recommendations for the most powerful "marine" speakers? They will be to the right of my throttle and to the left of the passenger up high. Being in these positions the most likely will get wet in a storm or big waves.
Thanks for the advice.
www.sbonh.org
OCDACTIVE is offline
Old 01-05-2011 | 09:36 AM
thisistank's Avatar
Is there a reason why you have to put "marine" speakers? I've never run any marine stereo applications on any of my boats (all have had large stereo systems). If you want super clear, loud sound, check out Focal's.
thisistank is offline
Old 01-05-2011 | 10:23 AM
OCDACTIVE's Avatar
A.T. Cult Member #4
I put marine because they most likely will get wet and I didn't know if that made a difference.
www.sbonh.org
Old 01-05-2011 | 11:23 AM
Focal's are the way to go for sure. I've been rained on a couple of times and they still sound great.
bms26 is offline
Old 01-05-2011 | 11:33 AM
animalhouse's Avatar
Focal K2 165KRX3 (3 WAY) will be the best for your aplication. They rock and are very sturdy. They are a bit pricey and do require their own amplifier, but you will not find a cleaner crisper sound. We run them in the dash faces of our 44 SL and can hear the music at 130 like your riding in a lexus. Note the tweeter and mid in the dash face, and the 6" componant under the throttle
Attached Thumbnails Speakers / most powerful-dscn0761.jpg
animalhouse is offline
Old 01-05-2011 | 11:42 AM
http://www.woofersetc.com/p7915/165K...ponent-Kit.htm
Screw that price!
kennyo is offline
Old 01-05-2011 | 12:06 PM
thisistank's Avatar
From personal experience, marine grade stereo equipment just isn't at the same quality level as non-marine application. I always mount speaker components at the gunwalls in the cockpit, exposed to the eliments and have never had a failure or issue with moisture (and this includes washing the boat and getting water directly on the speakers).
With that said, if you're looking for high end sound and you're picky about it, don't go with marine grade. If you're looking for loud "decent" sound, marine grade will be fine if you run it correct. Most of the major brands are producing marne grade stereo components including speakers...Alpine, Sony, JBL, Bose, JL Audio (JL being my personal pick and they make amps and speakers in marine grade) are some that will suit your needs for basic "loud party boat" sound.
I'd recommend PMing AudioFN...He's been in the business for a long time and can put you in the right direction.
Old 01-05-2011 | 12:11 PM
The reason for using marine speakers is because of the support material for the speakers. If you buy the Focals, other than their cheapest model, you're getting the same material as marine speakers. Same with the Polk Audio speakers. I'm running the 7.7" JL components and get a lot of compliments on how clear they are at high volume levels. I haven't heard their 6" speakers so I don't know how they compare. Which ever brand you pick, get enough amplifier. A lot of speakers are destroyed by distortion casused by inferior amplifiers. Of course that opens up the other can of worms......AMPS!!!!!
gare is offline
Old 01-05-2011 | 12:51 PM
DC Gold speakers. They have 5.25's or 7's. They sound great and are 100% waterproof. I run 8 of them in my boat.
Griff is online now
Old 01-05-2011 | 07:40 PM
Seriously don't forget about a sub-woofer. There are a lot of free air sub woofers that are easy to mount and do a pretty good job(not great). They seem to really make a big difference in the marine stereo installs.
Although, I just did a side by side comparison with a Clarion 10" FA sub and a 10" enclosed JL Audio sub. No comparison but they aren't close to being in the same price class. I just had to prove to myself that you get what you pay for with this stereo stuff. From what I've personally listened to; Focal, JL Audio, DC Gold, Polk Audio or any of the other high end gear will do you a very nice job. Cookie cutter stereo brand speakers will probably let you down if a really nice stereo rafts up next to you.
gare is offline
