Dart Big M Block
The Dart Big M block is heavier than the Merlin dry, but if you check the specs full of water the Big M is slightly lighter. Obviously the block will have water in it, thus I feel the extra mass makes the Big M slightly stronger.
Sampson: I highly recommend talking with the block manufacturer at great length. You really need to go closed cooling for block stability. Just my opinion, good luck.
