Peterbuilt Hot Rod
Old 01-11-2011 | 07:55 PM
Default Peterbuilt Hot Rod
Peterbuilt Hot Rod
Now that's a big block ....852 cu.in
Peterbilt Rod
12V-71 Detroit Diesel powered.
YEEHAW !!!!!!!!!!
Attached Thumbnails Peterbuilt Hot Rod-att1.jpg   Peterbuilt Hot Rod-att2.jpg   Peterbuilt Hot Rod-att3.jpg
Old 01-11-2011 | 07:56 PM
TeamSaris's Avatar
Driver-441
Racer
Cooler than sh!t
TeamSaris is offline
dykstra's Avatar
Awesome!!!!
dykstra is offline
Old 01-11-2011 | 08:03 PM
1 of the boyz are into the Rat Rods now but this Peterbilt is the CATZ AZZ
Old 01-11-2011 | 08:28 PM
wrinkleface's Avatar
Where's Herman Munster??????
wrinkleface is offline
Old 01-11-2011 | 08:54 PM
Badazz PERIOD
SkaterMike82 is offline
Old 01-11-2011 | 09:01 PM
tcelano's Avatar
12V71 with open headers must be the next loudest thing from a Saturn V rocket... You can hear x71 boat engines coming from 10 miles away even with wet mufflers.
Has to be the coolest thing I've seen in a while.
tcelano is offline
Old 01-11-2011 | 10:00 PM
How much oil does that thing take?
Mastercraft240 is offline
Old 01-11-2011 | 10:08 PM
JasonSmith's Avatar
Take or leak? On a 8V-71 the add mark on the dip stick is 1 gallon. This one is a 12V-71 so I'd assume it is close to the same.
Some Detroit Diesel info, the 1st number in the number of cylinders, the V is the style of block & the last number, 71 in this case is the cubic inches per hole. DD also made a 16V series in the 71 & 92 displacements.
JasonSmith is offline
Old 01-11-2011 | 10:09 PM
JasonSmith's Avatar
That thing was in Diesel Power magazine a few months ago.
