wanted 360 Chry heads >
Old 01-18-2011 | 07:29 AM
Default wanted 360 Chry heads
I need a set of Chrysler 360 heads old set are from a 1984 F32 Trojan. I have a set at the machine shop that have bad Cracking in the combustion chambers. non repairible.
any help.
fastestonehere is offline
Old 01-18-2011 | 03:20 PM
bcfountain's Avatar
Registered User
i gave two sets away about 3yrs ago.i think the guy still has them.what state are you in?
bcfountain is offline
Old 01-18-2011 | 07:27 PM
ohio. Columbus
Old 01-19-2011 | 09:00 AM
try Fisher marine 734 848 6721
lightning jet is offline
Old 01-19-2011 | 01:40 PM
fantastixvoyage's Avatar
http://detroit.craigslist.org/wyn/pts/2155927319.html
fantastixvoyage is offline
Old 01-19-2011 | 04:39 PM
I am by no means an expert on Chrsler heads... are they marine specific? If not give Sean Donley at 3C Salvage a call. They usually have quite a bit of Mopar stuff. He's up in wooster...
I'll pm you his number.
RT930turbo is offline
Old 01-19-2011 | 04:49 PM
I don't believe so, only thing is watch the casting numbers. There are some early ones floating around out there without hardened exhaust seats. 360s are also different from small port 318 too. Oh and make sure they aren't for the newer "magnum" series engines either.
Old 01-19-2011 | 06:51 PM
casting # 4027163 thanks i now found out i need two sets. can you tell me if these are the early ones you speak of.... Thanks
Old 01-19-2011 | 11:18 PM
sac
I have a pair,casting #3233344,I also have a fresh short block bored .030 over.Came out of a 1986 Wagoneer, I was building it for a jeep and putting aluminum heads on it but lost interest in the project.
sac is offline
