Steering helm going out...replace or go hydraulic? >
Old 01-19-2011 | 06:08 PM
Default Steering helm going out...replace or go hydraulic?
My steering helm will need replacing and a new cable in the near future. I have been trying to decide rather to just replace the helm and cable or upgrade to some type of a hydraulic system. I have read many threads on here that said going hydraulic external steering is only needed for going over 80. Right now I only run about 60 but I do plan on upping the motors in the 3-5 years if I don't upgrade boats first. What are your recommendatios on steering system for this type of setup. I would appreciate brand names etc if possible. I have twin 454's with Bravo one drives.
FuelinAround is offline
Old 01-19-2011 | 07:09 PM
Hydraulic steering is great, I have used WPM with good success and it is easy to install just takes time and attention to detail. WPM was the most economical. Imco, latham are good brands. You've got it bad, your boat will not likely be worth more$$$$$ with upgrades such as this. I personally now wouldn't own a performance boat without it, but make sure you're going to own it long enough to make it worth your while. Give Hardin and Teague a call for a quote.
SkiDoc is offline
Old 01-19-2011 | 09:05 PM
Lol yeh I don't expect to sell this boat for a profit....I will look into those systems... Are they external or internal?
Old 01-19-2011 | 09:13 PM
Looks like $2500 for dual ram kits .... What is the best alternative? Is there a helm/mechanical aftermarket kit that is really good?
Old 01-19-2011 | 09:37 PM
Rookie's Avatar
I know that people say if you are not over a certain speed than no need for full external hydraulic steering. It was the best improvement I have ever added to my boat!!! The boat is more stable at ALL speeds, the boat rides like it is on rails. Once you add full hydraulic you will wonder why you didn't do it sooner. I highly recommend getting it.
Rookie is offline
Old 01-20-2011 | 05:50 AM
The hydraulic assist systems add a margin of safety but do not feel great at the helm. They work by using the steering cable to initiate the movement. When you start to turn the wheel you feel some resistance then it gets easier. If you do it, go the entire hydraulic system. I was not happy with the hydraulic assist and added the helm right away.
SkiDoc is offline
Old 01-20-2011 | 07:32 AM
Thanks for the input.... Can full hydraulic be installed with motors in place or do they have to be pulled? How many estimated hours to install?
Old 01-20-2011 | 07:57 AM
c_deezy's Avatar
It will take about 8 hours or so for somebody that doesn't do it all the time, but I like to install all the thru-hull stuff one day, then leave it to let the sealer set up overnight.
It's really not too bad to install. I like the Mayfair stuff, its reasonably priced and pretty nice.
Based on CP's price, you are looking at about $3600 for dual bravo/dual ram full hydro. You can piece out the inside stuff, but really you don't save much. And the nice thing getting the entire kit is that you get every part you need to install.
Last edited by c_deezy; 01-20-2011 at 08:35 AM. Reason: can't read a price list...
c_deezy is offline
Old 01-20-2011 | 08:20 AM
I have Hydraulic steering, but its not "full" hydrualic. Is there a kit to make it complete, or do you have to start all over?
cabin fever is offline
Old 01-20-2011 | 08:34 AM
c_deezy's Avatar
http://www.cpperformance.com/c-796-i...ulic-kits.aspx
c_deezy is offline
