Need Part Numbers... >
Old 01-20-2011 | 03:37 PM
Default Need Part Numbers...
So im pulling my seawater pump and alternator this weekend. Does anyone know if there is a rebuild kit part number for the pump on a carbed 525SC? Also, Im pulling the alt so I can upgrade to a higher amp as well. any suggestions on where to buy a decent 150 amp (maybe larger) or a part number so I can do some searches for one?
xsboost525 is offline
Old 01-20-2011 | 11:01 PM
It just uses a standard Bravo sea pump kit.
It depends on what you want to replace as to which kit to get.
http://boatfix.com/bykeywordmerc.asp...kit&texttype=2
Griff is offline
Old 01-21-2011 | 09:38 AM
Ive never rebuilt the seawater pump since I bought the boat, because it was new when i got it. I was told I could run 2 seasons depending on the hours and I should replace the impeller. What would you suggest I change besides that?
Old 01-21-2011 | 10:19 AM
Change the plastic housing if it has any grooves in it. At a minimum, change the impeller and SS wear plate.
Eddie
Young Performance is offline
Old 01-21-2011 | 10:34 AM
Thanks Eddie! I really appreciate the help.
Old 01-21-2011 | 11:13 AM
Once you get the pump apart, and the impeller off, be sure to spin the pulley, and make sure the bearings in the pump turn nice and smooth, with no roughness or growling. Sometimes the seals can go bad, and water gets in the bearings. Bearings and seals are replaceable
MILD THUNDER is offline
Old 01-21-2011 | 12:59 PM
Im sure I'd be better off just ordering a full rebuild kit instead of just replacing one or two parts. At least that way I will know its all good to go. thanks guys
Old 01-22-2011 | 02:20 AM
You need to know if you have a 1 piece body or 2 piece. If a 1 piece will fit, then they get #46-807151A14. On my Pantera, a 1 piece kit would not work due to where the motor mounts were. If you get a 2 piece kit, then get #47-59362Q 7 as long as the body looks good inside. The body rarely gets bad on them. If teh body looks bad or is cracked inside then get #46-72774A89.
Boatfix is about the cheapest place I have found for impeller kits. They are Merc kits. Don't use junk Sierra kits.
Griff is offline
