anti siphon valves >
anti siphon valves
anti siphon valves
Old 01-29-2011 | 09:03 AM
Default anti siphon valves
would a 2000 42 have anti siphon valves in the main and aux tanks ? thanks
575cat is offline
Old 01-29-2011 | 12:16 PM
Default valve
No , they were building there own by then, absolutly not from the factory.
Driveguy is offline
Old 01-29-2011 | 01:29 PM
good to know, thanks alot
575cat is offline
Old 01-29-2011 | 02:05 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Wouldn't every tank have to have these valves to be USCG compliant, regardless of who/where they came from?
US1 Fountain is offline
Old 01-29-2011 | 02:30 PM
USCG rules require every fuel tank to have anti-siphon valves. My 1999 and 2007 Fountains both have them. They all have them.
GF?
Got Freedom? is offline
Old 01-30-2011 | 10:14 AM
well I checked a saddle tank, you cant pull the tube out all the way but managed to fish a cable down the tube all the way, with the pickup tube pulled out as far as I could and found no obstruction , just kept pushing the cable all the way through, and did the same on a main tank ?
575cat is offline
Old 01-30-2011 | 06:56 PM
Ginger or Mary Ann?
Did you remove the hose barb on top the tanks to do this check?
Old 01-31-2011 | 07:12 AM
I removed the fuel suction hose , hose fitting, so I could have room to turn the fuel 90 degree pickup and pull it out as far as I could , 8 to 10 inches or so and then fished a fine cable down the tube and it kept on going deep into the tank ,this boot was built from the factory with 750 griffin blower motors so I am thinking the valves were never installed . one of the main tanks I did the same thing with the cable and I could stuff 2 + feet of it through the tube , thanks for the response .
575cat is offline
Old 01-31-2011 | 08:02 AM
Default valve
You may be right about CG regulation. But you may be allowed if fuel system have a shut off valve Im not sure, the CG gave the approval for them to put a build certification stickers on the tank , fill, vent, and pick-up assembly and there was not an anti- syphon valve
Driveguy is offline
Old 01-31-2011 | 08:55 AM
Ok what does a anti siphon valve look like, I am sure that you could not put a 1/16 cable throuh it ?
575cat is offline
