zz502 vs. merc 502mag >
Old 02-01-2011 | 10:37 PM
Default zz502 vs. merc 502mag
hey so i have a boat with a 502mag.... last owner didnt drain water so im looking at a motor with a cracked block...(cracked bad)
i found a guy with a zz502 forsale in my area and was curious how interchangeable these would be.... technically it would be a little more hp and a little more ft lbs.... but could i use my mag intake on it and what are your thoughts about the swap....
morrowcarl72 is offline
Old 02-01-2011 | 11:20 PM
I'm guessing you have a mag carb motor, 415 hp? You will probably want to take the cam, intake and heads off of your motor and put it on the zz motor to correct the power curve to fit a marine app. The reason for the head swap is that I would tend to think that you'd be better off with whatever valves that Merc uses opposed to the valves that GM puts in their zz motors. Make sure it is a brass freeze plug motor. Someone else may know about the zz valves and be able to provide more info though.
Double check the compression ratio of the zz motor, but I thought it was 8.5 - 8.75. If it's over that with your iron marine heads you could have a problem.
wjb21ndtown is offline
Old 02-01-2011 | 11:34 PM
mine is a 95 efi mpi mag motor
my plan was to use the whole zz502 but take the carb and intake off and use mine.... plus my oil pan and oil cooling plus all my fuel system and alternator distributor and starter....
those were the major things i picked up from this forum.... most guys said they even ran them factory with no issues for many seasons....
like i said this motor is cheap with little to no hours on it.... (less that 50 in a car)
mine is all toast (intake is the only good part)
im looking to do this as cheap as possible but still be able to go 75ish!!!!
boat is a 95 mirage intruder 217.... external hydralic steering 16in trim tabs bravo 1 and a 25p mirage 3 blade
Old 02-02-2011 | 01:30 AM
You would need to have the ECM recalibrated for the ZZ502. Also, I don't think the cam in it usaeable with stock Merc exhaust as it would revert water.
Griff is offline
Old 02-02-2011 | 08:05 AM
Also if they used the long block zz502 it will have GM performace parts large oval heads. Your intake is rectangular port.
Why don't you just find a used block and have all of your parts switched over? A good machine shop can do this for you.
Ok, I just read your last post. Now you want to go 75 ish. Get out your wallet because you are going to need 500HP or so to do that.
jeffswav is offline
Old 02-02-2011 | 08:53 AM
75ish will not happen cheap , unless you just happen to have a spare 525 sitting in the corner of your shop. On the other hand I guess it all depends on what you consider cheap.
Jeff P31 is offline
Old 02-02-2011 | 09:23 AM
Here is another idea for you. Buy the engine complete, get a marine carb, marine distributor, aftermarket exhaust with long risers. You will need to upgrade the oiling system, bigger cooler, bigger better lines and fittings. That would get you your 500HP assuming the engine it what he says it is. That should get you near 70 MPH on GPS. The "Dream O Meter" will always read faster.
jeffswav is offline
Old 02-02-2011 | 10:13 AM
I agree.
You can sell your stock EFI unit for a decent price and cover the cost of most of the swap. You'll have to go to a carb or spend a ton of money to get that efi system over 500hp.
You could probably sell your old rotating assembly, cam and lifters, EFI system and the 502zz large oval heads and cam out of the zz motor for decent money (around $2k for everything if the crank, pistons and rods are still good). You would be better off with a HP500 cam or a crane upgrade, keeping your heads, and getting an Edlebrock airgap or single plane intake. As mentioned though, you're going to need to upgrade your exh. system to the tune of around $800-1,200 if you want to make this happen.
Old 02-02-2011 | 12:53 PM
The average ZZ502 GMPP crate motor will have an honest 510-515 HP at the listed 5200rpm. I tend to agree with Jeffswav on the route to take.
More "stuff" needs to be done to make the motor marine friendly. Don't be alarmed. It is a short list. I.E. oil bypass valve.
PM me and I can fill in the details.
ZZ502 with a dash of PC.
ROTAX454 is offline
Old 02-02-2011 | 12:54 PM
Wink
Most of the GM Performance ZZ502's are equipped with some medium size aluminum oval port heads that unless your MPI efi setup is the small oval port type it will not mate up with the heads on the ZZ502 and unless you boat in fresh water or have closed cooling, running the aluminum heads will require careful flushing after uses. You might want to buy the ZZ502, sell the heads and use the money to upgrade your MPI heads if they are rectangle port.
A good cam change in the ZZ502 similar to the HP500efi cam, brass or stainless freeze plugs, swap your marine oil pan and such and the ZZ502 base block will make a good build up platform.
As you probably already know finding a good 502 gen 5-6 bare block or a new one will set you back $1800 -$2500 if you can find one so buying an existing ZZ 502 may be a better move.
Best Regards,
Ray @ Raylar
Raylar is offline
