93-97 99-02 454mag where is 98? >
Old 02-03-2011 | 11:34 PM
Default 93-97 99-02 454mag where is 98?
a few places iv looked online for superchargers or any motor performance part they list either 93-97 or 99-02 454 mpi mercruiser....what happened to 98? my motor is a 98 did i get the odd ball year? is there a difference in a 97 98 99?
prostock3 is offline
Old 02-04-2011 | 02:16 AM
Dave M's Avatar
Veteran: Navy
Did you verify it is a 98 by your motor's serial number? That might of been a transitional yr. I think one diff. with the 99 and up was the serp belt setup.
Dave M is offline
Old 02-04-2011 | 07:20 AM
good point, what number in the serial number would tell me the year?
Old 02-04-2011 | 08:02 AM
28Eliminator's Avatar
96-97 I think was the transition year. They ditched the VST tank and lift pump, and went to the cool fuel system. I think that is also when the serp belt was used.
Here is a manual for the 98. http://www.mercruiserparts.com/selec....asp?type_id=8
28Eliminator is offline
Old 02-04-2011 | 08:10 AM
1997 was the transition year for the cool fuel system and I believe 1998 was the transition year for the serpentine belt system. I have a 1997 with the cool fuel system and v-belts.
Gimme Fuel is offline
Old 02-04-2011 | 08:25 AM
Dave M's Avatar
Veteran: Navy
My 97 had the cool fuel system but no serp belt.
Here's the '98 right here...
http://www.mercruiserparts.com/selec...M+454+V-8+1998
Check to see if your serial is in that range.
Oh, and don't assume that if your hull is a '98 that your motor is too.
Dave M is offline
Old 02-04-2011 | 09:37 AM
98 is an odd ball year. It is the rear they transitioned from V-belt to serpentine and from a Mefi 1 to Mefi 3. Some engines had a V belt and Mefi 1, some had Mefi 3. The same with the serpentine, some had a 1 and some a 3. The only way to tell is by serial #.
If you are looking to supercharge it and you have a Mefi 1, than plan on replacing it with a Mefi 4 ecm and harness. If you have a 3, then you are good to go. The Mefi 1 has no way to tune in boost. All of the tuning is basically done with fuel pressure and injector pulse width.
Eddie
Young Performance is offline
Old 02-04-2011 | 12:02 PM
Eddie
Does the Mefi 1 use a 1-bar MAP sensor? What happens if you go out of range with a Mefi 1? Let's say you put a blower on an engine with Mefi 1...once the MAP goes out of range, what does it do, anything?
STV_Keith is offline
Old 02-04-2011 | 04:46 PM
Mine was a 97 with VST and V-belts.
As Eddie stated, If you have the MEFI3 that would be your best option for upgrading.
Old 02-04-2011 | 10:49 PM
It will only read up to 100 Kpa. It does not recognize anything over that. It will still think it's 100 Kpa. The Mefi 1 doesn't have any boost tables, so there is no way to tune in boost or run a 2 bar map sensor. That is why Merc used the Mefi 3 on the 575 SCI. Of course, we use a Mefi 4 now. It's a much better piece than the 3.
Eddie
