anyone have a dyno that will handle high hp? >
Old 02-05-2011 | 10:37 AM
BigSilverCat's Avatar
Default anyone have a dyno that will handle high hp?
we have a new engine that we can only tune the low hp stuff up to around 1800, and we need to find someone with a dyno that will handle alot more to tune it when we turn the boost up.
anyone have a dyno with dual water brakes?
anyone have anything with a very large water supply so we can do constant load testing for long time? minuites? hours? with out boiling the water?
Tyson
BigSilverCat is offline
Old 02-05-2011 | 01:02 PM
animalhouse's Avatar
We have had 3500 ft. lbs on our dyno.
animalhouse is offline
Old 02-05-2011 | 02:24 PM
Check with Mark at Precision Marine.
www.pmefi.com
BradH is offline
Old 02-05-2011 | 05:07 PM
We have 1000 gallons in reserve and 2000 hp + brake dual rotor Supply pump too big it had to be regulated down.
Come and take a look or call, plus we are not that far.
Jim
573 346 5250
www.ozarkspeedandmarine.com
thumper038 is offline
Old 02-05-2011 | 05:40 PM
WeaponX's Avatar
I was about to post up Jim but you beat me.
Attached Thumbnails anyone have a dyno that will handle high hp?-8.30.09-146-large-.jpg
WeaponX is offline
Old 02-05-2011 | 05:53 PM
Also we can run our full wet cmi's with 8 egt's and o2 sensor
Have adapter to run dual cooler rear mount starter as well.
Jim W.
Old 02-05-2011 | 07:49 PM
Those motors look bad ass
mr buttonhead is offline
Old 02-05-2011 | 08:13 PM
Smitty's Avatar
Mark at Precision runs 2 diesel truck engine brakes. I'm sure he can handle the power.
Smitty is offline
Old 02-05-2011 | 08:32 PM
Running for minutes or hours is the deal killer with most dynos. That is a lot of water and cooling capacity! It would be difficult to keep the absorber water cool, let alone the engine coolant. I'm not saying it can't be done, its just a big under taking.
JeremyAnderson is offline
Old 02-07-2011 | 10:31 AM
Default Dyno
Couple pictures of Dyno with 1075 Merc with marine set up.
Short video on facebook or in Skater section.
Attached Thumbnails anyone have a dyno that will handle high hp?-img_0007.jpg.jpg   anyone have a dyno that will handle high hp?-img_0005.jpg.jpg
