Will Merc 10-qt oil pan work with offshore mounts? >
Old 02-05-2011 | 11:08 AM
Question Will Merc 10-qt oil pan work with offshore mounts?
Does anyone know if the stock Merc 10-qt pan will clear the offshore style motor mounts cradle that wraps under the engine? My old 454 had the smaller pan. Don't want to spend the $$ on a Merc pan if it's not going to clear.
Budman II is offline
Old 02-05-2011 | 07:11 PM
If the pan came off of a stock blue or black Merc engine then it is only 8 quarts. However, yes it will clear an offshore type mount.
Eddie
Young Performance is offline
Old 02-05-2011 | 07:36 PM
i have the stock mercury racing pans 10 qt with the kickouts on both sides and they clear w no problems w offshore mounts on my cig i also have 2 new 10 qt pans for sale
smokin' gun is offline
Old 02-06-2011 | 02:45 PM
Do you need to run a ministarter with the kickouts on the pan?
Old 02-06-2011 | 02:56 PM
Usually and a remote oil filter.
picklenjim is offline
Old 02-06-2011 | 02:58 PM
In that case, I would prefer to stick with the Merc pan.
Old 02-06-2011 | 02:59 PM
Eddie
Are you referring to the pan that has the sump that extends approximately 3/4 the length of the pan? I thought these were 10 quart.
Old 02-06-2011 | 03:08 PM
I am talking about the one that looks like this:
http://www.ebasicpower.com/pc/MER845...Gen.%20VI.html
Old 02-06-2011 | 03:20 PM
I got rid of a T style and went to this. Very happy with it.
http://www.summitracing.com/parts/MIL-31557/
Can stay with the full size starter and I run the long 2 qt. filters right off the block.
Old 02-06-2011 | 09:04 PM
That pan is only 8 qts.
Eddie
