Stainless Marine
Old 02-10-2011 | 12:21 PM
Audiofn's Avatar
Charter Member #232
Default Stainless Marine
How can you tell the different generations of their exhaust manifolds?
Put your best foot forward!
Audiofn is offline
Old 02-10-2011 | 02:23 PM
PhantomChaos's Avatar
The older ones look older than the newer ones. Likewise, the newer ones look newer than the older ones. Hope that helps.
PhantomChaos is offline
Old 02-10-2011 | 04:02 PM
OldSchool's Avatar
LMAO!!!
Google is a powerful tool!!!!
OldSchool is offline
Old 02-11-2011 | 12:25 AM
Gen II is way smaller and only has a round hole ont the top where the tailpipe riser bolts on.
Gen III is bigger and has an oval hole where a second aluminum riser bolts on that also has 4 ribs in it and then the tail pipes bolt on to that !!!!
Gen II is actually kind of like the GIl manifolds..just better.
THE GEN III IS THE SH!TS !!!!!! would not want anything else then these ..mine are over 8 years old and never had any problem !
DareDevil is offline
Old 02-11-2011 | 08:37 AM
The Gen III is port-separated, the old standard is not. Gen III is mostly 5", the standard is 4".
BROWNIE is offline
Old 02-11-2011 | 08:46 AM
I like my description better.
Old 02-11-2011 | 09:13 AM
The older gen2 had larger exhaust port openings and less material for gasket sealing
baja27 is offline
Old 02-12-2011 | 12:47 PM
Wow, are you telling me you can read my posts ??? Nobody else can..LOL
