HELP! Dead Battery, Can't Open Engine Hatch >
Old 02-14-2011 | 09:35 PM
Default HELP! Dead Battery, Can't Open Engine Hatch
Left the boat sitting too long and now can't open the engine compartment lift to access the batteries due to a dead battery. Will a cigarette light style booster/charger do the trick or do I need to take more drastic measures?
hopper75 is offline
Old 02-14-2011 | 10:12 PM
That should work as long as the lighter works with the key off. Another thing you can do is connect a charger up to your fuse board to the pos and neg coming in to it. Small charger, I wouldn't go over 10 amps max. Let it charge slow for a while.
picklenjim is offline
Old 02-14-2011 | 10:28 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Can you access to apply power directly to the back side of the hatch switch?
US1 Fountain is offline
Old 02-15-2011 | 12:26 AM
I have had this happen also. Some battery chargers will not actually start charging a totally dead battery. Easiest is like was said before, just hook up to the power lead going to the fuse box and to a ground. I have had to hook up an actual battery to open my hatch before, due to the type of charger I had. I have also had to hook up a charged battery to a low or dead battery to trick the charger into actually charging the dead one.
uhpguy is offline
Old 02-15-2011 | 12:39 AM
i once use a power pack at the fuse box and just open the hatch.
zx14k is offline
Old 02-15-2011 | 01:12 AM
X2
Thats the simplest way if you can get to the back of the switch.
Griff is offline
Old 02-15-2011 | 04:05 AM
Sell the boat (quick)
Mine has a pos and neg post behind the dash just for this.. yours may too.
silent lucidity is offline
Old 02-15-2011 | 09:35 AM
Default Fixx
And once you get the hatch open, install a onboard charger and all you will have to do is plug it in..
FIXX is offline
Old 02-15-2011 | 11:53 AM
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
+1
Baja_342 is offline
Old 02-15-2011 | 01:20 PM
Originally Posted by Baja_302
+1
AMEN to that!
jason35 is offline
