Velvet drive reversal? >
Old 02-15-2011 | 09:28 PM
I have a 30' Scarab II with bbc (standard) rotation hooked through the B/W trans, down to a set of TRS Drives. The port foot dropped a gear, and I was told by several different marine mechs, that there was no difference in the starboard or port gears in the foot. Well long story short, I had to put the port engine in rev to go go fwd! I have changed the "lefthanded" prop to a "righthanded" one. Now the boat goes fwd but doesn't handle near the same, and the steering is fighting to the starboard side. Can I change the rotation of the trans or foot and go back to my lefthanded prop on the port side? Without changing the foot or gears in the foot? Any help would be appreciated!
toyman496 is offline
Old 02-15-2011 | 09:40 PM
Mbam's Avatar
Offshoreonly Advertiser
You can have the lower switched, housing & gears are the same. Differant prop shaft and 1 bearing if I remember correctly.
Mbam is offline
Mbam's Avatar
PS - you cannot do it in the trans
Mbam is offline
Old 02-16-2011 | 08:37 AM
Like MBAM says, you would need to switch the propshaft. You cannot do it by reversing the trans. Also, by running the trans in reverse to go forward, you can very easily damage it. They are not meant to take alot of power in reverse.
MILD THUNDER is offline
Old 02-16-2011 | 09:46 AM
they are correct in that the gears are the same. different propshaft and assembled differently. also I have trs drives or lowers for sale, cheap.
JIMG is offline
Old 02-16-2011 | 11:16 AM
I think the confusion is that you can reverse a B/W tranny but only for a reverse rotation motor. It just fixes the fluid flow.
f_inscreenname is offline
Old 02-16-2011 | 11:02 PM
Thank-you. What exactly would I have to change in my lower unit to accomplish counter rotation? I still have my original foot, good shafts, good housing, bad pinion gears.
Or, does anybody want to trade my new setup for a counter rotation setup?
And again, thanks for all the information!
Old 02-17-2011 | 06:00 AM
Mbam's Avatar
You can see the part list here:
http://www.mercruiserparts.com/Show_...SING+%28TRS%29
Mbam is offline
Old 02-18-2011 | 03:19 PM
Thanks! I did'nt know that all I had to do was turn the gear around in the foot and use the extra bearing with the left hand shaft! I've had all of these parts, now maybe I can get it pointed in the right direction! I really appreciate the input and I am glad as heck I joined! Thankyou
Old 02-18-2011 | 08:14 PM
Don't know what your plan was about changing this around but it's not something most can do with out the proper tools. The pinion gear will need to be shimmed and the bearing preload will need to set. This requires special tools usually shops only have. You can't just change parts around with out them being set up properly or the drive won't live. It's best to leave this to be done by a reputable shop with the right tools.
picklenjim is offline
