hydraulic steering helm-char lynn #? >
Old 02-27-2011 | 09:21 PM
Default hydraulic steering helm-char lynn #?
i need to make sure i am looking at the correct helm for my setup. i have a latham ram, 7/8 with 8" stroke. i think i need a char lynn 211-1007-002. ideally i would like to be around 2.5-3 lock to lock if possible but i am not picky
regalman4925 is offline
Old 02-28-2011 | 01:33 AM
c_deezy's Avatar
That is the typical part number.
I have one that I bought and never used, it is in new condition, never been used. Let me know if you are interested.
Attached Thumbnails hydraulic steering helm-char lynn #?-img00017-20101025-2005.jpg   hydraulic steering helm-char lynn #?-img00018-20101025-2005.jpg
c_deezy is offline
Old 02-28-2011 | 07:13 AM
the part number isnt exactly typical, for exzmple the 211-1007 that i am looking for is a open center, 3/4 port and 4.5 placement while the 1009 has 7.3. if i used the 1009 i would have like 1.5 turns lock to lock. how much are you willing to sell yours for?
Old 02-28-2011 | 07:56 AM
Rookie's Avatar
211-1007 That is a 75cc helm which is the typical size that Imco sells for their single cylinder steering.
HC-1 page 106
http://www.imcomarine.com/nvcatalog/imco_2009.pdf
Rookie is offline
Old 02-28-2011 | 07:58 AM
ok so we will call it "typical", is it the correct size is what i need to know????
Old 02-28-2011 | 08:22 AM
Rookie's Avatar
V=(r^2)*3.14*8" we need your cylinder bore size.
But you should be between 2.3-2.9 for a typical steering cylinder. And C deezy's should work for you, which is the same part #.
Rookie is offline
Old 02-28-2011 | 11:50 AM
bore and stroke are in the first post. i think his will work also...
Old 02-28-2011 | 04:33 PM
c_deezy's Avatar
Sorry...by typical I meant what is typically used in a boat for full hydro, at least what I've seen in the past.
I forget what I paid for it, I'll go $200 out the door for it.
c_deezy is offline
Old 03-01-2011 | 09:56 AM
Any idea if this would work on a twin-ram setup? What else would be needed?
dba900 is offline
Old 03-01-2011 | 11:06 AM
No a single ram will not work on a twin ram set up.
violator is offline
