K Plane trim switch - any ideas where I can source one? >
Old 02-28-2011 | 04:05 PM
Nicolasticity's Avatar
Default K Plane trim switch - any ideas where I can source one?
Trim switch for a Kplane as picture seems to be an ETN manufacturer?
Numbers on body are 8928
and part number 8544K2T34
any ideas where I can get one.
I dont have a perfect connection 0.23ohm/20Kohm setting
Attached Thumbnails K Plane trim switch - any ideas where I can source one?-dsc00239.jpg
Nicolasticity is offline
Old 02-28-2011 | 11:48 PM
tcelano's Avatar
CP Performance has (well at least 6mo ago) them. Don't worry about the color. You can pop the rocker button off and swap them when you get your new one. They have both the single pole and dual pole.
tcelano is offline
Old 03-01-2011 | 12:22 PM
tcelano's Avatar
Back at regular computer. Try this link:
http://www.cpperformance.com/c-178-rocker-switches.aspx
tcelano is offline
Old 03-01-2011 | 12:38 PM
cheers - I have 6 connector does that make it double pole - or doesn't it work like that?
Old 03-01-2011 | 01:11 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
yep, double pole. DPDT=double pole double throw
(ON) OFF (ON)= Momentary ON-OFF-Momentary ON
US1 Fountain is offline
Old 05-09-2012 | 07:55 PM
J-Bonz's Avatar
Just did a search and found this thread.... What is the difference between a Single Pole and Double Pole switch that are both Momentary On - Off - Momentary On?
http://www.keitheickert.com/p-13093-...ngle-pole.aspx
http://www.keitheickert.com/p-13092-...uble-pole.aspx
I take it both do the same. Is my assumption correct? A double pole has 6 posts while a single has 3?
A double pole would be ideal for operating both tabs or drives at the same time?
Just trying to figure out what I should buy...
Thanks,
Jr.
J-Bonz is offline
Old 05-09-2012 | 08:03 PM
Ginger or Mary Ann?
Yes.
double pole is basically 2 switches in 1 that work in unison. Operates 2 circuits.
Old 05-09-2012 | 08:19 PM
J-Bonz's Avatar
Originally Posted by US1 Fountain
Yes.
Thanks for the quick reply! Know I just need to think through what which one I need..................
J-Bonz is offline
