Boat Cover Cleaning?
Old 03-02-2011 | 12:01 PM
Default Boat Cover Cleaning?
How do u guys clean ur boat covers? I have a "new to me" 27ft mid cabin boat and the covers were in the ski locker when I bought it, but b/c of the rain recently and the boat being outside at the dealership for a day, the bottom of the ski locker was damp, and so was a portion of the cover.
Im not to concerned with the outside of the cover, since the rain is now cleaning that . But to prevent any smells from the inside of the cover is what im more concerned about.
DirtyJerz is offline
Old 03-02-2011 | 12:09 PM
A couple of times a year I hang mine over the fence and scrub it with a brush and soapy water. Dries quick like that and I usually hit it a couple of times. Gets all the grime off of it. If you have heavy mildew or something you might need a stronger cleaner. A dehumidifier in the boat is a good idea also.
jmeng is offline
Old 03-02-2011 | 12:12 PM
I agree with jmeng! I keep damp rid in my cabin works excellent...Just refill the container 2 or 3 times a month depending on where you live.
seans36baja is offline
Old 04-07-2011 | 04:42 PM
ItsPeanut's Avatar
Does anyone have a suggestion for a good cleaner. Also would you recommend using a pressure washer??
ItsPeanut is offline
Old 04-07-2011 | 05:26 PM
If you pressure wash it don't hold the nozzle to close to the material, as it could damage it. I use dish soap and warm water to clean mine and once it is dry, I spray it with water repellent.
AB From Windsor is offline
Old 04-07-2011 | 06:32 PM
Ive thought about taking mine to a commercial cleaner and having them run it through the washing machine on delicate...
Has anyone tried that?
soonenough is offline
Old 04-07-2011 | 07:17 PM
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
Mild soap and water. Hang and let dry thouroughly. Don't use anything too strong. You'll clean off the waterproofing. Im a big skier. I try to to wash my ski clothes very often. The aftermarket waterproofing never is as good as the "factory".
Baja_342 is offline
Old 04-07-2011 | 09:09 PM
Pick up some Spray 9 at Home Depot, best cleaner that I have found.
richanton is offline
Old 04-07-2011 | 09:27 PM
x2.
Perlmudder is offline
Old 04-08-2011 | 12:11 AM
Throw it in a swimming pool overnight. I have a full black cover on my Fountain CC and thats how I clean it. Works amazing and no work other than vacuming the pool. The chlorine in the pool isnt enough to hurt the cover but will kill/remove any mold/mildew. You might need some brick to weigh it down.
Next best is to soak it in a garbage can or big rubbermaid bin with the same chlorine content as a pool. Agittae now and then. rinse well.
Mr. Demeanor is offline
