Post your fuel consumption? >
Old 03-02-2011 | 07:05 PM
KN
Default Post your fuel consumption?
Please post your boat Make/Model/Length and Power, and how much fuel you consume at cruising speeds/top speeds and what those speeds are?
KN is offline
Old 03-02-2011 | 07:27 PM
Sonic 31ss twin 454s average 1.5 mpg
FuelinAround is offline
Old 03-02-2011 | 07:37 PM
CigDaze's Avatar
35 Cafe Racer, Slightly warmed over 502's, about 450 hp per side. At Cruise, I'm consuming 14.9 gallons per hour per side at 3500 rpms which is exactly 50 mph. So, I guess that makes it 1.67 mpg at cruise. I never took readings at WOT; I really don't want to know.
CigDaze is offline
Old 03-02-2011 | 07:47 PM
Don't want to know !
Alpha Tango is offline
Old 03-02-2011 | 08:06 PM
seafordguy's Avatar
?? Is this a mis-print?
seafordguy is offline
Old 03-02-2011 | 08:19 PM
excursion's Avatar
43 Black Thunder 500 efi's, XR's at cruise 3500 rpm 1 mpg
excursion is offline
Old 03-02-2011 | 08:36 PM
CigDaze's Avatar
Nope. Turn-key and go!!
I've learned my lesson. Nothing beats reliability. I do damn near 200 hours a year. I want to boat, not wrench.
CigDaze is offline
Old 03-02-2011 | 09:11 PM
Default What uses More fuel?????
What uses more fuel... A built SINGLE IO or A pair of mild bbc?
slpcamaross97 is offline
Old 03-02-2011 | 09:22 PM
2.2 mpg with a labbed 28" Bravo 1. Just got a labbed 29" Cutting Edge prop so I'll see if the mpg goes up. Hopefully the top speed will increase. I will be doing some charting on both props to see how they compare.
VetteSteve is offline
Old 03-02-2011 | 11:08 PM
FREEDOM US1's Avatar
Skater Brother
.5 miles per gal 110.
FREEDOM US1 is offline
