Flipping/Turning over a boat/hull
I would like to flip my boat/hull over in order to straighten out the bottom, fix gouges, and paint it. Can anyone post pics of what they used to turn over their boat? I can make something to hold it, just wanted to see what others have used. Everything will be stripped out, almost to the bare hull. Hell, even turning just 90 degrees would make this job much easier (thinking similar to a car rotisserie for frame off restos)....
Can you thru bolt a pinion to the outdrive mounting holes and make something to support the front section of the hull???
Here is how somebody did it:
http://www.offshoreonly.com/forums/f...g-my-hull.html
You shouldn't need to flip it completely over, but being able to rotate it to do one side of the botttom at a time would definitely make things easier. Some big foam blocks would work good.
I know this may sound stupid, but you just want to lay undernith it when hangine fully rigged incl. engines and fuel on some A frames..... reason beeing, if you unrig it it will actually make the hull move some ..and if you then blueprint it ...after putting everything back in it will be OFF !!!!
Not kidding either..been there done that !
My brother and myself did it on his 23' Glastron. Not the heaviest by any means. Used a long steel pipe going into the bilge, fastened inside to the engine mounts and at the transom with plates bolted to the holes. With a larger pipe that slid over that pipe acting as a bearing, used a chain and chain hoist wrapped around the larger pipe section and connected to an over head beam. At front, used an engine hoist connected to a strap looped thru the bow eye to keep it from sliding forward. We ended up having to run a couple of ropes from the strap to a point rearward, to keep the strap from slipping forward over the nose as we rolled it over. Very surprised at the amount of force required to get it just vertically. A lot of weight in the bottom keeping it bottom heavy.We ended up using a come-along on one of the rear u-bolts to help pull that side up to flip it. Just go slow and watch whats going on. The size/weight of your boat may require more HD equipment than the engine hoist we were able to use.
We painted a guys here locally by raising the front. He had 12ft ceilings I believe. We took the boat off the trailer and set the back on tires then lifted the bow way up in the air so it was at an angle
Thanks for all the info guys. I agree, I'm not going to turn it completely over, even 45-70 degrees makes it more accessible. I just have to figure out how to support and turn the front, the back is easy. What about some heavy timbers cut to the profile of the hull made as a half cradle?
The hard part is getting it to "roll" in a controlled manner.
