Seals for dry throught transom exhaust >
Old 03-03-2011 | 10:06 AM
bigboat28's Avatar
Default Seals for dry throught transom exhaust
Where do you get the seals for dry exhaust that goes through the transom?
bigboat28 is offline
Old 03-03-2011 | 11:18 AM
Default fixx
eddie marine.
http://eddiemarine.com/store/cart.ph...l&p=11434&c=58
FIXX is offline
Old 03-03-2011 | 02:12 PM
I bought just the rubber seal from CP Performance and they were only like $10-15.
cdail28590 is offline
Old 03-03-2011 | 02:42 PM
I made my own. I took a old innertube from a semi tire and cut it to fit. went that route cuz i needed custom fit.
MILD THUNDER is offline
Old 03-03-2011 | 02:47 PM
We use the tail pipe seals that CMI sells. It doesn't take very long for these seals to stretch and distort so they become relatively ineffective. Does anyone have seal that works better?
BenPerfected is offline
Old 03-03-2011 | 02:48 PM
CP has the seals and transom rings you need. You should also get a second set of the actual seals while your at it.
I have a spare set of rings and seals but I'm in Australia so that's probably no help to you!
Ghostrider is offline
